Gmrs on UV-5R
DJBio
PEI
I put the gmrs and frs on my UV-5R radios and trying to get them to work with the dewalt radios we have at work
We are using channel 2 and the ctcss is on 11 what do I need to set my t-ctcs to so I can talk to the dewalt radios
I can listen to them but can’t transmit to them
sloop
Lewisville, NC
Are you using CHIRP to program the radios? Ctcss tones only go down to 67.0. You need to find out that tone your work radios are set to inorder for them to hear you.
DJBio
PEI
I did use chirp but now trying to do it right on the radio
rf_patriot200
Freeport, Illinois
The more people illegally using radios the more problems will be caused and the sooner something will be done about it.
Well that's true, but if it's Frs that gets scrapped, then are we really losing anything? Anyway that's enough of that so we don't get sidetracked from the op's question.
DJBio
PEI
When I go into the settings the tones into the talk and receive will not save keeps putting things back too off
DJBio
PEI
You can't change tones on an existing memory channel. You have to delete the channel and start over.
Ok so have to change it in Chirp and reprogram the radio ?
hill
Middle River, MD
FRS Radio won't get scrapped.
You will just have to use this service as intended with approved radios with non-removable antennas with proper emissions power and bandwidth.
Going forward that is what the OP should doing instead trying to enter the frequencies into not a FRS Radio.
People are doing a lot to harm to this service by just programming FRS frequencies in any non-approved radios and thinking it is ok.
