GMRS Radio Etiquette...
Aviation_Scanner
WSEY205
Houston, Texas
Got my GMRS licence a couple of weeks ago and now was wondering, what is proper radio etiquette when using GMRS.
I have read elsewhere that you should monitor & listen in first, but then what do you do once you would like to talk on a given frequency (simplex).
KevinC
The big K
Super Moderator
Home
Doesn’t answer your question, but who do you plan on talking to on simplex? That probably won’t go more than a few miles and I doubt anyone would hear you.
I’d see if you can hit the “Memorial” repeater as I hear a ton of radio checks there.
Aviation_Scanner
WSEY205
Houston, Texas
Do you have the info on this repeater? I can't find it at mygmrs.
Although I doubt that I could hit it with the stock antenna on the radio I will be receiving.
KevinC
The big K
Super Moderator
Home
Looks like it may be a closed repeater and require permission to use it. It's 462.725 DPL 627 (the input DPL is different I'd imagine) FWIW.
You can join Texas GMRS Network and get access apparently.
Aviation_Scanner
WSEY205
Houston, Texas
Any luck?
Put in an application to join, but haven't heard back yet.
I might try it on simplex first until I get approved, but in addition to the above, the GMRS frequencies programmed into my GMRS radio don't match the ones on the GMRS frequency band that I found.
Plus, I bought the wrong programming cable, so had to return it and wait on the right one I ordered to get here (Should get here by Friday), so I can program the right frequencies.
