Mastiff2013
- Joined
- Apr 8, 2013
- Messages
- 74
How would a MXT400 radio be powered if it will be used in house? Is there any way to convert it to use household electricity?
Google "12v Power Supply". It's common for mobile radios to be used as base stations.
If you have a power supply with adjustable voltage output, you can adjust the output voltage to match the fully-charged state of the battery, and then connect the battery in parallel with the power supply.
Why run a battery in parallel ? Just run off of the D.C. Power supply. A battery won't be able to recover fast enough from voltage drop, even when a trickle charger is inline when under load.
Not true, if the battery has enough capacity to run the radio on its own. Otherwise, how would a UPS react fast enough to maintain power in an outage???
Every battery has a finite capacity and will eventually go dead. But that doesn't mean it won't seamlessly pick up the slack in a power failure until it does go dead.
Then you admit this statement is wrong. UPSs do exactly that every day--recover seamlessly from dips in AC voltage or complete loss of AC power by switching to battery power nearly instantaneously.
Using a battery charger as a power supply is a bad idea. Many chargers use pulsed or unfiltered DC outputs (particularly lead-acid chargers--it reduces electrolysis of the electrolyte) that work fine for charging a battery, but will induce loud background buzz or hum when transmitting, even with a battery in paralell.
to put back the capacity you drained while using the radio for any length of time would take a large cost prohibitive solar array
Solar has gotten a lot cheaper. You could build a solar setup capable of powering a typical HAM radio 24x7 for less than $1000, including the storage batteries for operating at night and charge controller.
