GMRS use on HAM radios
pjose411
Tustin CA
I have a GMRS license. Is it then illegal to use these Baofeng UV-5RXP if I just programmed the GMRS channels and lock it down? Thank you in advance. Wanted the kids to be able to ride around the neighborhood and call home. I realize there's cellphone but you know what happens with kids and cellphones these days...Thanks in advance- WRDT695
Hit_Factor
Saint Joseph, MI
Ham radios are not type accepted for GMRS, so it would be an illegal use.
If the kids follow the transmission rules and properly ID it's very unlikely to be an issue.
pjose411
Tustin CA
I copied and pasted this from Amazon so lots of bad english. I'm a complete newbie to all this, please be kind, rewind. From what I can tell it will operate within the bandwidth/freq and settings. I guess my biggest concern is since these are able to hit Ham radio freq will it make it illegal to be used for GMRS by my immediate household family. Would have to teach them how to properly ID when transmitting..which is another topic I will save for the correct part of the forum. Thank you all.
  • UV-5R Upgrade More Fashion And Wider Version;High / Low Power Settings (8W/5W /1W) Programmable Amateur Radio
  • Frequency Range: 65-108 MHz (Only commercial FM radio reception) VHF: 136-174 MHz(Rx/Tx). UHF: 400-520 MHz(Rx/Tx)
  • Up To 128 Customize Channels;Bulit-in LED Flashlight;VOX/ Function;RX CTCSS/DCS Scan
  • Full 2000mAh Battery(non-oversized in capacity); Broadband (Wide) 25khz / Narrowband (Narrow) 12.5khz Selectable
  • Programmable by PC ;AUTO Keypad Lock;Dual Band, Dual Display and Dual Standby
PCTEK
Northern California, USA
In order to operate a Wouxon, Baofeng and other imported HAM radio's you umust have at least a technician class FCC License. A GRMS license (which I also have) covers you and your family but only on designated GRMS frequencies. HAM radio operators are very good at recognizing unlicensed operators.
mancow
N.E. Kansas
Your confusion is rooted in common sense. A normal person such as yourself would think that a device with the exact same specifications would meet the requirement and thus be allowed. Alas, this is the government we are talking about. Unless they waive their hand and sprinkle their regulatory holy water upon it which manifests itself in the form of a sticker bearing the mark of bureaucracy you may as well be trying to use a spark gap transmitter. After all, these markets won't manipulate themselves.
pjose411
Tustin CA
I actually emailed the FCC, let's see what they come back with, this way no misinterpretation, doubt they will let me play dumb if I get fined for using non-approved equipment. I will post if they ever respond. I primarily wanted to use the GMRS license so I can get a better set of radios for my family as we live/work within 5-8 miles in case of emergency. Doubt I will get everyone to get their technician's license. But I know that when that massive earthquake here in CA hits we are going to need a way to get in touch with each other. IT's been rocking and rolling around here since 4th of July.
Hit_Factor
Saint Joseph, MI
Do you already have the radios? If not, look at the chart I posted BaoFeng makes GMRS radios too.
ko6jw_2
Santa Ynez, CA
The BTech GMRS V1 is a type accepted radio. It will only transmit on GMRS channels, but will otherwise receive in the same ranges as other Baofengs. Not legal for FRS. Programmable with Chirp. Repeater capable.
With regard to type acceptance, there are differences between the actual GMRS specs and the specs of other Baofeng radios. The differences are greater with regard to FRS use because of power output and detachable antennas. Baofeng gets away with all of this because they say their radios are for ham use. Very dangerous to turn people loose with a radio that can transmit anywhere. In Japan they simply don't sell these radios. Forget type acceptance, they are not legal period.
To say that this is subject to debate is like saying a speed limit sign is only a suggestion. Will you go to jail for using a non type accepted radio. I doubt it. Will you cause interference to licensed users - possibly. Will you endanger your ham license - you bet.
This all comes down to the slightly dubious idea that radios will help you in an emergency. If you really want to help join an ARES or CERT group. Red Cross and Salvation Army too. Get some training and get to know other people who you can rely on if needed. Like if you can't locate a family member or you become separated. Time and again I encounter folks who are concerned about their family's safety, but give little thought to their community. Radio will not save your life. If everyone gets on GMRS or FRS and starts calling in an emergency there will be chaos. Ham radio will not necessarily be a lot better. I have a ham license and a GMRS license.
Look at mygmrs.com it lists GRMS repeaters all over the country. There may be one is your area.
alcahuete
Southern California
Is it illegal to use that radio? Yes.
Does anybody care? Eh. GMRS/FRS has largely become a wasteland in many places, and is largely ignored just like the CB band. Unless you're doing something really stupid and drawing all sorts of attention to yourself, nobody is going to care.
Channel 1 where I am (which is largely the only channel that ever sees use) is just a free-for-all. Roger beeps gallore, kids, cursing, music, illegal amplifiers, etc. If your kids are using the radios properly, IDing properly, etc., I can guarantee you that nobody is going to care. The FCC has way bigger fish to fry than a family using non-type accepted radios properly on GMRS.
N4KVE
PALM BEACH, FLORIDA
It’s one thing to use part 90 radios on GMRS. Yes, they are approved for commercial freq’s, but they are still not part 95 GMRS approved. That won’t get you in trouble, but using a ham radio to transmit above 450 MHz is totally illegal. But as others said if you do it on the downlow, nothing will “probably” happen. This means asking permission from the GMRS repeater owner to use his repeater, vs pulling up in some strange town with the wife, & kids, & using someone’s GMRS repeater. Remember, it’s not ham radio with the repeater open to anyone who has a license.
