vini_i
I'm trying to use GNUradio with an RTL-SDR to read the data transmitted by my vehicles keyfob.
I can receive the signal with SDR#. So that I don't have to sit there and push the keyfob button over and over I wanted to put together a simple chain that could simulate the keyfob signal. My best idea of what to do is to feed two separate frequency signals into a selector and the to switch between them with something to make a pseudo frequency coded signal. My best effort was to feed a signal source set to a zero to one square wave into a probe signal and then use the probe signal as a variable. This failed terribly. The selector does not recognize the probe signal as a variable. I'm not sure what else I can do.
My understanding of GNUradio if very limited. Is there anything else I can do?
