Good motorola mobile?
BlackSheepDue
Naples, ME
I currently have an xpr7550 which I'm very happy with and I'm toying with the idea of getting a mobile for my car some time this summer. Naturally I'm leaning towards the 5550 but I wanted to get some input from those that know much more than I. I've had a few portables but never a mobile so this is all new to me. I don't use dmr and I have a BCD536hp in the car so it doesn't need to have any fancy capabilities but I'm sure as is the case with portables if I get a newer mobile it will either be p25 or dmr. Finally I can get the 5550 programmed for free so that's another selling point. I'm open to any options though!
Thanks,
Thomas
Skypilot007
Medford, NJ
I was in the same situation as you. I opted for the XPR5550 to simplify programming. I already had a 5550 in my shack so it was a no brainer. Only one P25 repeater around my area for amateur use so I just use my old XTS3000 for that.
BlackSheepDue
Naples, ME
I'll most likely end up with the 5550 because I know I'll like it. It will be used to public safety conventional vhf so I just wanted to see what else people used. Thanks for the insight!
N1GTL
CT
I have the XPR7550e and the XPR5550. It really comes down to what you want to hear, or more accurately, what you can legally transmit on. I have the BCD436HP to monitor P25 and I have the DMR enhancement installed so I can hear TRBO systems on that too. Since my job involves installing DMR/TRBO systems, the scanner is a better tool than an XPR radio. The XPR does not offer a way to put in a "wild card" for a talk group. That alone helps in a huge way. You will not regret an XPR5550 purchase as long as you can RX P25 that you want to hear on your scanner.
BlackSheepDue
Naples, ME
I can only legally transmit on 2 disp frequencies and a dozen tac channels all of which are conventional vhf so the dmr or p25 capability doesn't matter to me but like I said in my original post if you want to buy a radio today you have to get one or the other.
Project25_MASTR
Millennial Graying OBT Guy
Texas
If they ever migrate digital on you there is always the chance what you currently own will not be the correct radio. Personally, I'm not a fan of Kenwood radios, but they do have a model which can be upgraded to include both DMR and P25.
The nice thing about the XPR4000 and XPR5000 mobiles, the programming cables are cheap and easy to build (~$8). XTL and APX cables aren't as easy to build due to the extra cost of the accessory connector.
That's the downside. I was hoping there would be a mass exodus to Capacity Max before I saw the pricing (since it was on a Tier III basis). Simoco has monitor and has a very well working Tier III product line but of course, most of the DMR air time systems in the US currently are either Capacity Plus or Connect Plus.
BlackSheepDue
Naples, ME
I'm glad you mentioned the cable. My capt(and good friend) programs my 7550 but I don't think he has the cable for a 5550. They use the same cps though right?
If anything goes digital around me it will most likely go p25 but I'm completely lost when it comes to p25 mobiles and if they're anything like the portables they're more than I want to spend. My father has an apx6500 so I don't think I would have to pay to get an apx series programmed either.
Can anyone shed some insight as to what my apx options are?
NavyBOFH
Where idiots grow on trees
If you have a 7550 the 5550 is the best step towards a mobile... especially if they are in the same band. I do the same for mine and it lets me set up the codeplug on my 5550 perfectly and then drag-and-drop everything into my 7550 codeplug and write it over to the radio. The bluetooth also makes life MUCH easier in the end where I can program both radios without pulling out a single cable.
I would opt for the DMR radios in the end, especially in your area, because if you are already on VHF then when you get a ham license you can just add the DMR repeaters in and have some fun.
N1GTL
CT
Yes, same CPS... You can make a cable for next to nothing. Take any USB A to B cable and cut the "B" end off. Use the 26 pin connector that the 5550 comes with and install the green, white, red and black wires in pins 1, 2, 3, and 4, in that order. Program the radio from the rear connector.
N4KVE
PALM BEACH, FLORIDA
I made my cable this way. Works great. I also added wires for the speaker, & ign sense to the same plug. This way the cable is plugged in 24/7. Right now, clean used XPR4550 mobiles are going for $300. I actually prefer the 4550 to the 5550.
NavyBOFH
Gary that's a great idea. I am taking that idea for my XPR mobile. I am already doing the same configuration for my Astro Spectra.
