Hello, I've been tinkering with MURS radios and have been looking for a simple mag-mounted mobile antenna. I've run into an RX performance problem on everything I've tried so far.
I tested 2 different Nagoya UT72 antennas which are supposed to work great with MURS (~152-155mhz.) These are 1/4 wave at VHF, coil loaded at the base and about 20" tall. I measured both antennas below 1.5 SWR and there were no apparent problems with the coax. These did increase transmit range but actually reduced reception range significantly... To the point where the stock rubber duckies inside the car have 5 times the RX range as when connected to the antenna on the roof of the car. I tested this with 3 different models of MURS radios and RX with a UV5r set to the same frequency. They all did the same thing. Also tried multiple vehicles, different positions on the roof, and different pigtail attachments to the radios with no luck.
I just tested another cheap-o mag mount UHF/VHF antenna that is a similar size to the UT72, but a different design at the base. It did the same thing.
The local NOAA channel (162.400mhz) had the same issue when connected to any of these antennas. Often no reception even though the signal was strong enough to be picked up with no antenna connected to the radio (even without a rubber ducky.)
Any ideas what would be causing this? I was really hoping to find a workable compact dual band antenna in case I ever want to get into GMRS. But would be open to trying something longer and/or dedicated to VHF instead.
Thanks for any input.
