Tracker
Happy New Year, Tracker! We are not communicating. Humor me and type more detailed responses. There is no reason to be in a rush. Try to use the same terminology used by the EZScan Software, and/or on the face of the radio, and/or on the LED screen of the radio. This way we can actually tell what you are doing. As examples:
1) Responding to brownlab's detailed (~300 words) instructions with
"I tried tried this in the morning before re synchin with my laptop, buy it didn't pick up miami... ...yesterday I programmed miami dade "coubty" fire rescue n that it did pick up................." and "I tried this under EZscan n Miami is Not under Systems........"
leaves me with doubts that his instructions were followed or even understood.
2) Responding to my own
"......... This second paragraph is regarding a completely different subject then the first paragraph in said response. Please let me know if you see MORE than ONE "Folder" at that step (between Continue and Copy Folders) in the "Copy Configuration to Scanner Memory/SD Card" process........"
with
"I did not get that prompt for more folders.......it just warned me that clicking continue would overife the info. on thr SD card...Btw, I just completed the previous mentioned regiment to no avail......"
leaves me with similar concerns.
One more time, from the top, lol:
EZScan software............Click on "Scanner/SD Card" tab (upper left)... ...MAKE SURE SCANNER IS TURNED OFF........Click on "Copy Configuration to Scanner Memory/SD Card"... ....."Overwrite Warning" popup select "Yes".....On my computer I now highlight EZSCANDG (H) (Your file system may be different).......Click on Continue......
STOP RIGHT THERE----- TOUCH NOTHING!!!!!
You should be looking at a popup box labeled "Select V Scanner Folders to copy"!! ARE YOU LOOKING AT A POPUP BOX LABELED "Select V Scanner Folders to copy"???? If so, you should see one OR MORE entries (lines of boxes and words) under FIVE COLUMN HEADINGS labeled "Copy" "Del" "VS#" "Folder" and "Description". DO YOU SEE THESE FIVE COLUMN HEADERS???? If so please describe, to the best of your ability EXACTLY WHAT YOU SEE UNDER THE FIVE HEADERS!!!! Then hit the "cancel" button at the lower right of this "Select V Scanner Folders to copy" popup screen.
That's enough for now, please respond to ONLY these very specific questions regarding ONLY this "Select V Scanner Folders to copy" popup screen with as much specificity as you can muster.
Thanks,
Rob
Clicked on "Scanner/SD Card" tab .. ...MADE SURE SCANNER WAS TURNED OFF........Clicked on "Copy Configuration to Scanner Memory/SD Card"... ....."Overwrite Warning" popuped up n selected "Yes".....On my computer it is EZSCANDG (E) ......Clicked on Continue n it started to rewrite the SD......n now it says "file copy complete," but I haven't done or touched anything else..if you want pics, you can e mail me at Dragrazor@aol.com
Sorry for my previous short answers
Ozzy
