Just tested for Tech and General, and in the database.
I have a little HT Baofeng, but realistically, what is the minimum set-up for an entry level user? Thinking one unit base/mobile.
Thanks!
Second, take a look at you local library for ARRL books on ham radio. Or look online at this site:
ARRL :: What's New
I like the ARRL Handbook ($50) which is a great reference manual and touches on many aspects of ham radio as well. The other books for new hams are found here and come in many flavors depending on your interests.
...but realistically, what is the minimum set-up for an entry level user?
pengyou1 ,
The ARRL books that K4EET recommends are good books. However, if you are on any kind of budget, you might want to got to a local ham fest and buy a used copy. The information in the ARRL Handbook and the ARRL Antenna Handbook doesn't change very much over the years. Generally, the only updates are some of the projects. You can get used copies in good shape, that are only a few years old, for $5 to $10. Then just read them until the pages fall out.
You can find ham fests that are close to you my going to the ARRL.org ham fest search web page and search on your zip code.
<snip>
Martin - K7MEM
<snip> Along with the guys here and depending on what your interests are I would suggest you seek out some "local" hams and make some face to face contacts too. Club meetings, ARES meetings or just calling one up if you can get a phone number has helped me. You'd be surprised on how inviting and informative your local hams can be, if just given the chance. I started out with my VEs and then branched off from there.... <snip>
First of all, congratulations! What callsign did you end up with?
Yes, you have already received some very good suggestions, but my question to you is what was your motivation to get into amateur radio? Certainly you must have had some idea what this hobby was all about. Was there some particular aspect that was of some interest to you?
I think if you can give us a little more information about that, that might help some of us do a better job of guiding you in the right direction.
Are you a permanent resident in West Lafayette or are you a Purdue student?Thanks for the suggestions. I just need to be patient and get involved with local clubs.
I've helped out the Tippecanoe County ARES team with the Wabash River Ride bicycle event a few times. Good people up there.
Pemanent resident. I will definitely look into RACES/ARES.
If for nothing else it will at least expose you to some local hams and you never know, you may end up finding an Elmer or two as well.
Guy in my ARES group has already offered to loan me a 2 meter base rig if I ever want it and I had only met him for the first time at our last meeting. You'd surprised how helpful and inviting hams can be.![]()
Congrats! Your call will suit you well if you end up with any Yaesu talkies lol. Clubs are not really necessary, unless you're the socialite. You'd be better off using those club dues on some new gear or antennas.Thanks for the suggestions. I just need to be patient and get involved with local clubs.
Call sign KD9FNB. Almost has a ring to it!
Most importantly, what's your budget? (You could easily spend $10,000 on a ham station). Also, what's your location? (Apartment or house)?
If you're not in an apartment (or subject to tough HOA rules), for an entry level tech station, I'd go for something like a Kenwood TS-2000 or an Icom IC-9100. These rigs give you 10 meters, 2 meters, 70cm (and 1.2 Ghz as an option). Not only that, but they give you single sideband on VHF & UHF.
Put up a 30-50 foot tower, (self supporting or eve mount), add a rotor and some long boom VHF/UHF beams and you could have lots of fun. For long haul work, six meters is usually pretty good during the summer E season. 1000+ mile contacts are easy.
When I first got on six, I used a 30 foot eve mounted tower with a 3 element Cushcraft beam. See --> Cushcraft Amateur Radio Antennas I aimed it with a cheap TV antenna rotor that I picked up used at a flea market.
