GP360 channel spacing
bigdoggg
North Carolina
I was trying to enter frequency 151.0937 MHz into a GP360.
I keep getting "frequency not divisible by either 5 khz or 6.25 khz"
and the frequency changes. Anyway around this?
CommJunkie
FM19xr
No. Frequencies end in either 0 or 5. Are you 100% sure of the frequency? 151.9375 or 151.0935 seem like more likely options, unless you have another space and can do 151.09375
bigdoggg
North Carolina
I have just took the time to verify with the FCC license. I am having the same problem with another frequency as well.
151.0925 MHz gets rounded to 151.09375 MHz
155.9025 MHz gets rounded to 155.90500 MHz
I am lost!
SteveC0625
Northville, NY (Fulton County)
I am lost!
Your GP360 is a European market radio. I am not 100% on European radios and frequencies, but it is quite possible that the GP360 can not do the newer 2.5KHz splinter channels thus you get the rounding. The other possibility is that European frequency steps are different from US. Either way, this is a major downside to trying to use radios manufactured for foreign markets in the US. That and they are most likely not type accepted for use in the US.
What version of the CPS are you using, and is it the US or European type?
SteveC0625
Not sure... It is R03.08.03_EN. I am guessing this is a European type of CPS???
Yes, that is the European version of the CPS. I am unfamiliar with that, but it's possible that what you have isn't very recent.. There is a lot of that going around, and the results are not good.
FWIW, if you are using this radio in any Part 90 application, you may be setting yourself up for problems communicating with others. That is one of the many reasons that I advise people to stick with the US versions in the US. The market is flooded with used European radios these days. They may seem like a bargain until problems like yours crop up.
CommJunkie
FM19xr
Doing a little research, the newest version of the CPS I could find for GP360 is 03.16.00, which was in 2010.
CommJunkie
FM19xr
It could have been updated to allow those splinter channels. It could also be a firmware restriction in the radio itself, and the CPS may not make a difference. I don't know enough about the European radios to know for sure. Maybe someone else might.
