I have been looking to buy a GP380 off ebay and I found this.....
95% New ! GOOD condition!
Motorola GP380 Two-Way Radio VHF
(136~174Mhz)
255 Channels Transceivers
With Accessorries
Item's Detail:
Motorola’s unique MDC signaling allows the transfer of data communications at the high-speed rate of 1200 bits per second.
The Forward error correction technology enables radio to receive message, like PTT-ID display, radio status and send out remote killing signal or emergency call even though the voice signal is too weak to be heard.
Expandable & easy to install in the field, by adding option boards like voice storage board & DTMF Decoder boards whenever your needs arise. The option board also allows up to 2 minutes of recording.
The plug-in mandown option board feature will trigger an emergency procedure in situations where the radio is horizontal or still for longer than a pre-programmed time. It is critical for radio users who work alone or in isolated environments.
The GP380 is certified by the US Factory Mutual standard intrinsically safe to operate in hazardous atmosphere.
The built-in voice-activated feature (VOX) enables users to transmit their message in a hands-free environment, without pressing the push-to-talk button.
Signalling - Quick Call II, DTMF
Power Output - 5W (VHF)
Option Board – Yes
Keypad – Yes
Display – Yes
Emergency Button – No
Battery Life-8hours(High Power)10Hours(Low Power)With Standard Hi-Capacity NiMH battery
MilSpec - MIL-STD 810C, D & E
Intrinsically Safe – Yes
Weight (gm/kg) - 428gms (With Standard Hi-Cap.NiMH battery)
Frequency-136~174MHz
Channels – 255
Dimension (H X W X D) - 137 mm x 57.5 mm x 37.5 mm ( With Standard Hi-Cap.NiMH battery)
The GP380 Features
Signalling
The radio software encompasses Private Line? and 5-tone selective signalling.
Channel Scan
Allows activity on different communications channels to be monitored and answered.
X-Pand? Voice Compression and Low Level Expansion
Crisp, clear and strong audio quality in virtually any noisy environment. Low level expansion allows further improvements in audio quality by reducing noise usually heard during pauses in conversation.
Voice Operated Transmit (VOX)
Hands free operation when used with Vox headset accessory.
Emergency Signalling
Sends a help signal to a pre-defined person or group of people. The help signal can contain a pre-recorded voice message enabling your whereabouts or status to be determined immediately by the receiving person.
Lone Worker
Added security and safety for individuals who work remotely from their team. The radio enters emergency mode if the user does not respond to the warning signal.
Option Board Expandability
You can expand the existing capabilities by adding one of the following option boards; Encryption for message security, SmarTrunk II for low cost trunking, Voice Storage option board provides voice recorder features allowing you to store and retrieve messages.
Whisper
Allows a user to speak quietly into a radio and still be heard clearly.
Call Forward
Allows calls to be forwarded to another radio user if you are unable to answer your calls personally.
User Information
A14-character alpha-numeric display contains a battery gauge and signal quality indicator and provides separate distinctive tones plus name decode for many incoming calls.
Ease of Use
Simple menus and an alpha-numeric contact list make the full power of GP360 simple and intuitive to use.
Status Calls
Pre-defined text messages which allow the user to send meaningful messages without talking.
Package includs:
Motorola GP380 VHF 2-Way Radio
New AC Charger (220V OR 110V, Depends on your country.)
New Battery 7.5V 1200MAh
Belt Clip
Antenna
English User Manual
Programming cable and software
Ok so From what i have seen this radio does not do MDC or QCII Is this true or not? Please help!
(136~174Mhz)
With Accessorries
Item's Detail:
Option Board – Yes
Keypad – Yes
Display – Yes
Channels – 255
The GP380 Features
Signalling
Channel Scan
Lone Worker
Whisper
Call Forward
User Information
Ease of Use
Status Calls
Package includs:
Belt Clip
Antenna
English User Manual
