paemt
I just bought a Gp380 off of someone who had bought it off ebay. I am trying to remove some channels from it with CPS R03.08.03, however whenever I try to read the radio it says cannot open port, check RIB/Device Power etc...
I have a RIBless cable I am using and a Prolific Serial to USB adapter that I have used before programming Minitor Pagers. Here is some information on the Radio if it helps:
Motorola GP380
SW Version: R03.08.08
CP Part #: 5107421A01
CP Version: R6.00
Model #: AZH25KDH9AN6
The person who I bought it off of used the software to program it, so I know the CPS works.
The only COM Ports I get when it is plugged in are 3 & 4 and both give me the error above. Is there a key sequence needed to put the radio into programming mode?
Motorola GP380
CP Version: R6.00
