GP380 Questions!
N1SQB
Somewhere On Earth
Well Here Goes!
I am relatively new to this particular radio's software.( Professional GP300/GM300series
Version D03.02.01 ). I have every parameter set up perfect, the way I want it without any errors coming up.
The only thing I cannot figure is how to set up a scan list. I have only 12 channels programmed. I set the amount of channels in the scan section to 12 but it is not scanning. The display shows the 2 directional type lines indicating that scan mode is active. However, when I key up the mic on another portable, which should cause the radio to stop scanning, it does not. I have cjecked all my TX RX pls and all match. I am able to break the squelch when I key up in manual mode. I dont get it. If anyone can help me out, it would be highly appreciated.
Manny
Skypilot007
Medford, NJ
I think you have to assign the scan list you created to a zone. Then it should scan and stop when the channel is active.
N1SQB
Somewhere On Earth
I understand that! I thought of doing the same thing. There is a section that asks you how many channels in scanlist-1. I listed all the ones programmed. It still does not scan them.
Manny
nukte
scan
Manny
Other areas also need to be programmed for scan - finally got it and when i find my notes I'll send
