GPH Radio
W6DMM
Forest Falls, CA
I just picked up a GPH, non-command radio. The keypad will not lock/unlock by holding the FCN button. Do these radios not have this feature? Also, I heard there's a way to enable the scan to scan all channels, not just by individual groups only. I've looked through the menus in programming mode and didn't see any settings for these issues. Any ideas? Thx!
rsmith7799
Arroyo Grande, CA
Go under GLOBAL SETTINGS, CONTROLS, TOGGLE SWITCH ASSIGNMENTS, GROUP SCAN. I would put it under the TOUCHPAD. As you go through FCN, these options will come up as you press the FCN button. Then under each GROUP SETTINGS make sure GROUP SCAN is checked (under Other Options, left hand side at the bottom.) As far as the LOCK/UNLOCK, it should...be there as you press and hold down the FCN button.
See how these work and get back us, we're here to assist.
