Do you use the GPS feature at all on any of your scanners?
I am just starting to get into location based scanning and have a question about RR database and geotagging.
I will uses two particular trunked systems from the county where I live in Virginia for my question...
In a system like Fairfax county where multiple transmitters are simulcast someone has arbitrairily picked a single GPS coordinates / range and submittied that to the db. Its fair to say they guessed at the cented of the coverage area of all the simulcast sites. When I go to download via what ever software I am using to program my scanner, if I select the software to download the GPS scanning data, assumingI like the data from the db I can use that for my circle of reception (or i can edit it.)
However, for a system like Metropolitan Washington Airport Authority, also a simulcast system, no one has attached any coordinates info - and it has just dawned on me why. It is a realitively low range system operationally - mostly within the confines of the airport, but it operates in two distinct locations seperated by large space inbetween (ie. the two different airports, Regan National and Dulles International.) However, after thinking about GPS scanning for a couple days now, it occoured to me that I could still set this up by creating two exact sites under the same system, instead of one, and having each site with the specific coordinates for the two different airports. Further though this thought process, I was wondering how this type of situation could be added to the RR database so that a system with a single simulcast site could have 'optional sets of coordinates' attached to it so that if you were downloading GPS scanning data via some programming software that it would automatically create the additional site(s) for you (but this wouldnt be a visible site when looking at the site data and frequencies on the RR db online.)
Specifically right now I am using a 996T for GPS scanning and I can manually set this up if I want to, but am wondering if it can be accomplished in the database.
Next, I am wondering how GPS scanning works for the Home Patrol - what data does the db tranfer to HP-1 to know to scan that site without GPS coordinates being recorded in the db? Does the HP-1 scan by coordinates from the db first and then revert to county heirachy from RR data (by some magic manipulation by someone behind the scenes with the weekly db updates) or would I just not hear anything that wasn't geocoded in the db if I hooked GPS to an HP-1? How does it work???
Any admins that use GPS scanning have any thoughts on this topic and my questions?
