GPS Question
licpl8man
Southbury, CT
Hi,
I have the Uniden BC-SGPS kit and both an SDS100 and BCD325P2. Is it possible to use the 1 GPS kit to feed both scanners at once? I ask because while the SDS100 is great on the trunked systems it doesn't do as well on the conventional stuff as the 325 does. Thanks in advance!
6079smithw
Near the Biggest Little City
Hi,
IIRC they both use 3V TTL signal so you're good there but you will have to cook up your own cable to parallel the units.
I did that with a 536 and a Kenwood TM-D700 with RS232 and it works fine for APRS in the Kenworth. Just use great care with
your connections, good luck. (BTW, born/raised in New Britain :))
