GPS Receiver for 996T
rfgroup
Rochester NY
I would like to take advantage of the GPS functions of the 996T. Can anyone suggest a GPS receiver that I could mount inside a windshield/on a dashboard so that I can take advantage of this feature? I know it has to be a serial plug on the cable. Thank you.
bob1857
That unit is all you need to take advantage of the GPS features in the 996 ?
wm8s
Houston, TX
What he said ;^) Works great. And I never unplug mine, it draws so little current. If you want, you can connect the puck to your PC and jack up the baudrate, but not necessary.
...R
N5FDL
Tracy (San Joaquin Co.), CA
Mounting and power
Uplink said:
I use the Garmin GPS18 PC OEM, $83 bucks at Amazon.com, it's PLUG-AND-PLAY with the Uniden 996T. See this post & thread....
I've just ordered one of these. How long is the serial cable and is here any issue with cutting off the cigarette lighter plug and replacing it with a direct or PowerPole connection? I am thinking about placing this in the rear of my Pontiac Vibe (with the ham gear and power strip) and run the serial cable up to the front and into the dash to reach the radio.
Thanks!
David
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
This would be a very good topic for another Wiki article, folks. Both the 996 and 15 have been out there for a while now, so a good list of compatible GPS units would be very helpful
73s Mike
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Ah, good catch Paul. I had totally forgotten that list was there. Mea Culpa
73s Mike
kellykeeton
Snoqualmie, Wa
you can also use any GPS that will dump NMEA-0183 ver.3.01 compliant, including GGA and RMC sentences
which is most of them from 1998 up as far as i know. I use some very old unit i found on the road one day.
ebay is full of old gps units that output to COM which will likely do the job for 10-80 bucks
Universaldecoder
Michigan
Don't cut the adapter
Thanks!
David
It's been awhile, but if I remember correctly the power supply circuit is in the cigarette lighter adapter. This means that the adapter converts 12v down to 5v for the GPS puck. If you cut the adaptor off and splice the puck directly to 12v, you'll fry it.
N5FDL
Thanks for the warning!
Gee, and I was about to have my car stereo installer do that! :roll: Thanks...I will find a way to take the power plug to power and route the serial cable into the dash.
David
N5FDL
Works as promised!
Ordered the Garmin GPS 18 PC from Amazon for $89.99 (free shipping, no tax) for my 996T, which is installed in the dash of my Pontiac Vibe, below a Pioneer AM/FM/CD/XM/iPOD receiver.
Having been warned, we connected a cigarette lighter power jack into the radio wiring and plugged the GPS 18 directly into the jack--as the adapter plug apparently steps power down to 5v for the GPS. Connected the serial connector directly to the back of the 996T. Added a extension cord at the same time so I can connect to the record out jack if I need to.
The GPS 18 worked perfectly the moment the radio was turned on. No special set-up required. As the unit only draws 50 milliamps we connected it to always-on power, so the GPS is running before the radio is turned on.
Now, I just need a scanning strategy for using the GPS!
Thanks for the reference and help.
David
UPMan
In Memoriam
Arlington, TX
Automatically turns on and off systems (or sites for Motorola and EDACS) as you change location. As I drive from SW Arlington across East Arlington, cutting across South then North Grand Prairie, into North Arlington then into East Fort Worth, my scanner automatically enables the system containing the patrol district I am in and disables them as I leave the district. I never have to push a button...just turn it on and drive.
N5FDL
I am now running a mix of systems that are GPS-controlled (that I want to listen to when I am close to them) and those that I want to monitor regardless of location.
For example:
I am working in an adjoining county to where I live. I always want to listen to the fire dispatch for the area of this county nearest my home. But, when I drive into the county I want to listen to additional dispatch channels--some of which cannot be heard from my home.
So, the channel I always want is in a local, non-GPS default system, and the system for the county in question is controlled by the GPS to turn on and off as I get enter and depart the area.
Trying to manage this uncovers some shortcomings in the software used to program the radio as you end up with lots of systems that have many of the same channels/frequencies in them but are used in different ways.
