BCD536HP: GPS Serial port won't retain setting
an39511
Cleveland, Ohio
I have two BCD536HP radios and one of them when I set the GPS serial baud rate to 115,200 bps it will not retain that setting when I power cycle the radio. It keeps defaulting back to 4800 bps. The other radio holds the setting. Both radios have the same firmware.
Also, I have sentinel configured to set the GPS baud rate to 115,000 bps but it does not seem to work either.
Again, this problem only happens on one of my units. Any Ideas?
MesquiteWx
Texas
Do you use one more than the other or has one been powered on longer then the other for any extended period of time?
an39511
Cleveland, Ohio
I discovered my problem is a corrupt SD card. I am able to read from it but cannot write to it. Formatting doesn't work either. What is odd is I use this radio for streaming online so it is on 24/7 and haven't tried to write anything to the card in quite some time.
