gqrx_dsd+
adcockfred
Aldine, tx.
stuck on getting audio out of dsd, running on gqrx.
audio input device #1 = (Pulseaudio) initialized
audio output device #1 = (Pulseaudio) initialized
adcockfred
Aldine, tx.
69 yesterday
I do not think I will be able to get the audio out to speakers with this conf.
my experience tells me audio out put should say something else other than
pulse audio.
there are a couple of good Linux guys on this forum
DRL-XM43
Durham Region
Within pulseaudio mixer you need to make sure you are directing the audio in and out to the right places. If you click on the audio destination boxes you get a pick list drop down of choices.
adcockfred
Aldine, tx.
yes that is pretty much it.
under pavucontrol playback gqrx out putting to virtual sink and dsdplus.exe out putting to built in audio
recording dsdplus monitiering virtual sink
but in terminal after launching
audio in device #1
audio out device #1
so dsd is telling me it is out putting the audio to the place where it is listening
audio out needs to say something different
but I am not Linux savey enough
so it appears I need another direction in alsa
DRL-XM43
Durham Region
I assume you installed a Virtual Cable? It won't work without it. (Virtual_Sink) Ok I see you have one we posted at the same time.
DSD+ in and out looks ok - it is pulsaudio settings which directs to the right place.
Audio recording does not seem like the right place, speakers do.
So hit the DSD+ selection box and see other choices, it should be speakers.
In my shot that would be (click on) the gray box that says "USB Speakers Analog Stereo, " that will drop down a choice menu like a pick list select speakers in the choices.
DRL-XM43
Durham Region
oh ok
then you mean I can run vac or vb cable on Linux mint
NO! It does the same thing as those but no - not those... it is puleaudio version of a Virtual Cable (Virtual_Sink) you need to install that.
Like I said earlier you need to have it or it won't work.
Search for Linux DSD+ for dummies, that article shows you how to install Virtual_Sink. Just follow the instructions and you should be fine.
adcockfred
Aldine, tx.
yes I did do the drop down box and it just ported the raw auto out to speakers
but if I can run vac or vb cables
I will try that when I get up in the afternoon and get back with you
I work graveyard down here in houston
DRL-XM43
Durham Region
This is what you need to do
Open a Pulseaudio file with this command
sudo nano /etc/pulse/default.pa
At the bottom of the file add this line:
load-module module-null-sink sink_name=Virtual_Sink sink_properties=device.description=Virtual_Sink
It should be all on one line like so:
Make sure to save it.
Re boot - you now have a VB Cable.
DRL-XM43
Durham Region
After you have Virtual_Sink installed, direct your gqrx audio output to it.
Launch DSD+, it will say audio in and out are both pulseaudio.
Launch pulaudio volume control playback tab (see my image above and make sure you have selected the right audio routing) DSD+ to speakers and gqrx from Virtual_Sink
DRL-XM43
Durham Region
Then what I do is....
Shut down Linux.
Start up Win10
... and do the same sort of thing easily and far better using proper tools for the job like FMP24 feeding DSD+ via tcp connection :)
(Linux peeps.... hold the flaming... this was my humor component post, ya know like HA HA Harf Harf)
I know that OP25 cannot be beat for audio quality it is why I take advantage of having multiple O/S so I can take advantage of SDR tools no matter what O/S)
adcockfred
Aldine, tx.
well ok moved d-star back to dmr on command line
that tells me at lease it is working
that got my decode back
but when I direct pulaudio to speakers I loose decode
that is why I think padsp corrupted
adcockfred
Aldine, tx.
thanks for the KISS advice
it did work, after I get the launching order down on the acer I will put the ssd on the I-5
putting in -rv and -fa gave me integrity on 3 dmr modes
I have learned my lesson on chasing these digital freqs
then I will move back to d-star
if you just knew how many years I chased T-III when my county friendly ran off the dome for rodeo
adcockfred
Aldine, tx.
hey raliegh
this acer laptop has cooled down now on the pad
yesterday I pulled audio on both slots on T-III
working fine now on nxdn-48
one cap+ system too
