I started scanning it when they switched on Monday. I was tracking the system while they were testing. The main thing to watch is they change control frequencies fairly often. Using the automatic definitions from RR did NOT allow SDRTrunk to see there were alternate controls available. You need to make sure they're all in your settings regardless of hardware/software.
They are also being weird. I initially set up in LSM mode for simulcast. This did work but then in working out more details I saw some oddities. Turns they are ALSO transmitting C4FM of the same data. I've never seen this before on the same system. Also they are NOT using TDMA which surprised me greatlt.
Furthermore fire has occasionally tested but is completely on the old system. Also small-town police dispatch (Jonesboro, Van Buren, etc.) is still on the old system. Thus we effectively have three law dispatch channels with no overlap.
Only two - Marion Police and MGH are totally on the new system. MGH is apparently the on encrypted channels I see and are not seen elsewhere.
If you are truly getting no county law or fire, something more is broken. To compare, you can check my calls feeds on nodes 1762 and 2469.
I'm willing to offer more advice but I've got to know a lot more details. I know several people who seem to have their Unidens working right, though generally with effort. What settings are you using?
