GRE-500 and WIN500
pawsrock
Jacksonville Fl.
Could someone please tell my how I move banks around in Win500? I want to move some banks down and add one up, but I can not find how to move them.
Thanks,
Ron Fone
DonS
Franktown, CO
There are no "banks" in the PSR-500. A scannable object (e.g. conventional channel, talkgroup) can belong to one or more "scan lists".
If you want change the scan list assignments for those objects, you'll need to do it in the "CONV" and "TSYS" tabs. Select the objects you want to move, then check/clear the boxes to the right under "Scan Lists".
Alternatively, you can use the "All Objects" tab and copy/paste one scan list at a time into a second P500 file, changing the scan list assignments as you go.
JoeyC
Senior Member
San Diego, CA
Not sure what you're asking since the 500 does not have banks but if you are trying to rearrange objects in Win500 use control and the arrow key to move them up and down.
