Gre 800 ?
home121
Florida
I dont think this has been asked b-4, o'k i've been adding new t.g. i.d.s in between the ones in use the only problem is when i , say 01-026 is active so i put in 01-027 fine, but 01-028 or 029 will not let me list same thing with 01-038 / 01-039 and so on 048/ 049/ 058/059, but all others are o'k. You might ask why i do this or maybe you can guess. Thanks
You cannot do it cause those are not valid AFS values. For example ... below are Decimal (on the left) and AFS values. You will notice that 01-028 and 01-029 are not valid. The AFS values end with a number from 0 to 7 .. and not 8 or 9. Hope this helps ..
150 01-026 151 01-027 152 01-030 153 01-031 154 01-032 155 01-033 156 01-034 157 01-035 158 01-036 159 01-037 160 01-040
