davidd2957 said:No need to wait any longer. www.lilkase.com offers a soft leather case with plastic window
Fits like a glove for the 500 series scanner. Check them out. They offer a lifetime guarantee on workmanship. I have a LilKase for my Pro-96 and Pro-97 and am totally satisfied.
David D.
I will be ordering one as well when I order my PSR-500. Excellent case.davidd2957 said:No need to wait any longer. www.lilkase.com offers a soft leather case with plastic window
David D.
n4jri said:Very nice case. At first I was afraid that they'd take a PRO96 case and have you stick foam in it like with the PRO97. But this one looks good. Also looks like you have a belt loop behind the swivel. Does that unsnap?
n4jri said:Suggestion on the rounded bottom: Is there room enough inside that you could wet the case and try to remold the bottom flap into something more concave? Or maybe try some rubber feet or rivets? It's just nuts that case that well-made and expensive won't sit up on a level surface. I wonder if the nylon one might fare better in this area.
n4jri said:On last question: Do you need to remove the scanner's plastic belt clip to fit it in this case?
CbusRog said:Good looking case. It looks like there's no notch for the LED though. I like my LilKase, and I know what you mean about the tippy scanner. With the LilKase, there's some slack space at the bottom. I'm thinking about placing a stiffener there. Maybe a piece of hard plastic or a chunk of old mouse pad.
