GRE PSR 500 and 600 Cigarette lighter plug?
billy245
Michigan
Where can I purchase a cigarette lighter plug that will work for these radios? I am assuming they are the same plug.
CORN
OKC
i bought a plug for my PSR-600 at Radio Shack. It's the plug itself. Just take the supplied DC pwer cable and slip the two ends into the plug by an easy press of an indention with a pencil.
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Certainly they can't be the same plug because the 600 uses 13.8 volts while the 500 uses around 6 volts, however, the 600 cable comes with the scanner.
thewenk
Idaho DB Admin
Eastern Idaho
Yes, you would need two different adapter/adaptaplug combinations, since the 500 is 9 volts and the 600 is 12 volts.
The PSR-500 adaptor is listed int the Wiki
http://wiki.radioreference.com/inde...accessories_.28Not_included_with_the_radio.29
The PSR-600 would need something like this Radio Shack adaptor, although I dont know which adaptaplug fits the 600.
Universal 12VDC Power Cord
Model: 27-1594 | Catalog #: 270-1594
Dave
