OK, so I know what the PSR-500 is capable of in terms of trunking, digital modes, freq coverage and so on. However I have a hesitation about purchasing one based on my current experiences with a GRE made Radio Shack Pro 97.
My concern centers around the sensitivity & selectivity. Here in Edmonton's urban environment, the PRO97 has performed very well on the rubber duck. However over time there became an issue with the BNC adapter on top. Currently, to maintain a signal, I have to bend the antenna with my thumb when listening, otherwise it is deaf. I have read some comments that the BNC connection on the PSR-500 can also be loose. Does this lead to the same situation I am currently facing with the RS Pro 97?
My second concern is what happens to the Pro 97 when I hook up an external antenna. It goes really deaf on VHF. Seriously. The local WX channel on 162.400MHz for example comes in loud and clear with the rubber duck. Attach the external antenna and the signal is just gone. Exactly the same thing happens on airband. Goodbye tower broadcasts. Now when I plug in my Kenwood THF7E (Ham handheld with wideband receive) and hook it up to the external antenna, every signal just gets stronger like it is meant to!
Having played with scanners for many years I understand that a base station / mobile would be better for use with an external antenna, but I don't have the funds to make 2 scanner purchases! I want the mobility of the portable, but the range afforded by the external antenna so I can listen to the aircraft, tower and approach frequencies at the 2 local airports (yes, I want to hear BOTH sides of the conversation like I can with my little Kenwood).
So...will the PSR-500 suffer the same problems as the GRE made Pro 97, or have improvements been made in this area of scanners?
Would you guys have any other recommendations for me?
Look forward to hearing from you!
Rob
Rob
