GRE PSR-500 Cases? Pouches?
akuser47
ohio
I am curious what you all transport your scanners in for protection so far I have been useing mine nonstop since this winter storm but it is at the mercy of the elements and I am using a ziplock to protect it. I am wanting to get a good case or MOLLE radio pouch to use for protection. I have seen different models that will work but what have you guys used??? Even with the pouch i will still use a ziplock to protect from moisture.
DiGiTaLD
I use the soft case. It won't help with drops, but it protects the radio from most other wear and tear. The clip is also pretty decent.
akuser47
ohio
Thanks guys I ordered the hard case car charger and a W-881 Super Gainer BNC Portable Antenna so I think I will be set for a while thanks alot
