I have seen this as well ....
Hi All,
I have seen this behavior on my PSR-500 and PSR-600. I agree with the OP , it is NOT desense .
I changed a few settings that made it better .These are :
TO MAKE SKIPPED CHANNELS better:
SQ Wait 1 - changed to 12
TO MAKE CTCSS DECODE better :
HD5 FADE - changed to 350
HD2 Holdoff - changed to 250
I have the same problems you have with BOTH GRE radios, The handheld is using the stock duck and the other is using a base antenna with a FM block filter from scannermaster . This seemed to fix the analog issue. However, I still have a problem like you mentioned but with Digital . If I set a NAC, the scanner will never stop on that channel. If I park on that channel it works fine. If I remove the NAC , it stops every time and even decodes the correct NAC but as soon as I save it stops working. I'm sure I can eventually figure out what settings work. Maybe change them one at a time . You will probably need to experiment and appreciate that at least you can try to tweak these settings .
