GRE PSR-600 bought used need help on getting it to scan
spoonfishn
Hi there guys, I'm new to RR, but been reading post here every time I need to get back on track on some issue I'm going thru either radio or scanning questions ,you guys are full of useful info. If only the rest of the world would be like this site it would be a better place.....back to what I logged in for
I bought a used psr-600 with I guess object imputed already and frequencies but I can't get it to scann if I. Hit man up or down I can get activity but it won't scan I've printed the users manual from the disk but it's kinda fust.to get it to work for me ,another thing is I can't get the south tx (Austin/lous/rio grande to relocate to my area,this scanner was in Houston tx I'm in McAllen tx 6 hrs SE of Houston but I can't get it to reprogram to my area unless it falls in withbin the same location ,if so how do I activatecthis feature it should give me the counties around me right? Any help here would be greatly appreciated I just need this scanner to start scanning analog and digital thanks my # and email 956-373-5052 spoonfishn@aol.com
puzzleriddle
bham, Bama
In your message you said nothing about the SCAN button try that & make sure you have the objects and systems assigned to a Scanlist..the default is scanlist 1 and have those activated
spoonfishn
Thanks ,let me go to the user manual and see if there is somthing on activating scan list ,I did not see anything in there but let me go back thanks a million,Fred south tx
spoonfishn
Thank you for your info will look for it and down load tonight thanks again ,Fred south tx
Macomb, Michigan
When you turn on the scanner. After it comes on press the scan button. Then press one of the numbers that are 1234567890. When you press one of those number it will either start scanning or say nothing enabled meaning nothing is programmed in there. Ihave the Pro 106 it's not like the PSR 600 but it programs the same way pretty much.
N8IAA
Fortunately, GA
Same difference. Have the 106 and 197. Try one of the scanner programs for the GRE's: Win500, PSREdit500 and download the scanner into the software. It will let you know exactly what is programmed and where it is. You will need the USB cable that came with the radio too.
HTH,
Larry
RickS31
Sunrise FL
Oslo,
Oh no! Whatever the case, please don't forget all your great "manual" advice you provide. I wouldn't know where to go for key presses on my 106 in an emergency.
Rick
Macomb, Michigan
I'll still give advice. Maybe I'll make manual for each State on how to program their Pro 106 in detail the best I can in lamens terms but then you got figure out what state and each county in the state what type of system they use.
