GRE PSR500 Power cord
FLYgirl89
Anyone know where I can find an AC power cord for a Grecom psr500 scanner? I am in Canada and have checked the usual places like The Source. Any suggestions? Thanks
ScannerSK
Gilcrest, CO
I found a nice one on Amazon. Hopefully they have it on the Canadian version.
My only concern with the one on e-bay is that it appears to be regulated while the original adapters are unregulated so therefore put out a higher voltage. The difference could affect the charging circuit of the scanner. I just checked the voltage on my original PSR-500 adapter and the output when not under load reads 14.16 VDC. Just something to consider.
DJ11DLN
Mudhole, IN
I used to use a wall wart from a big box store on my Pro-651, basically the same radio. Find the correct tip, polarize it properly, set the selector to 6V and off to the races. These can typically be had for less than $10 and I had zero issues with it until my granddaughter knocked the scanner off my desk one day. Now it won't work with any external input to the power jack.:(
FLYgirl89
Oh no!
FIRE321FIGHTER1985
Winnsboro, La
A word of advice, do NOT charge batteries inside the scanner. The charging circuit in most scanners are poorly designed and could cause damage to the scanner.
