Gre Psr500 :)
gregmoss
Alaska
Got my gre psr500 2 days ago from scanner master. Great service, fast shipping. The scanner itself, is totally awsome. Great Job!!! Gre!!!! Also got the newwest firmware upgrade without a problem what-so-ever. The scanner performs flawlessly :) all of the bells and whistles..
jwoody062
Indianapolis,Indiana
I have the PSR-600 and just got my 500 handheld radio today,can i clone the 500 from the 600 and will the dsp and cpu updates be updated/included from the cloned radio?
mikey60
Oakland County Michigan
You can clone the configurations between the two radios, but the CPU and DSP firmware updates need to be done via the computer.
Mike
gregmoss
Alaska
one thing i've noticed with the psr500 is the scan speeds kinda slower than the unidens i'm use to. Gre 60 scan rate compared too uniden 100 scan rate. I wish i could speed it up abit..
eyes00only
Denver Colorado
What's the latest version now? Also, what the heck is the DSP?
I'll check when I get home, but I think my CPU is 1.6.
JK
Mike_G_D
Vista, CA
Psr500
DSP = Digital Signal Processor
This is basically a microprocessor dedicated to and optimized for running algorithms that clean up and process digital signals used for communications (including but not limited to digital data that reflects audio including voice and music). In the case of the PSR500 the DSP is used to process the P25 digital voice decoding. It may also digitally decode analog FM (this is possible and done in some devices) rather than use a dedicated standard FM demodulation circuit but I don't think so in the PSR500's case. The firmware for the DSP can be updated separately from the firmware for the CPU which is the central processor commanding the overall unit.
Gregmoss,
That's odd! As I recall, all of the other posts I have read comparing the Uniden scan speed to the GRE unit seem to indicate that the GRE is faster. I don't have a Uniden to compare to myself so I can't really say. In any case, if your unit seems unusually slow I would check the programming. I don't know of any actual dedicated "scan speed adjustment" that can be changed but I think there are some expert settings that can be adjusted to make it scan faster albeit with a possible adverse effect in that the scanner may scan too fast for it to consistently lock on signals so you might miss some transmissions. However, I would check your Multi-Site mode settings. If you are using MultiSite and have it set to Stat it could really slow the apparent scan speed, particularly if you have the "Check all CC" option enabled, because the scanner has to check each CC in a TSYS (with that option enabled) before moving on to the next. I would make sure MultiSite is set to OFF on all of your TSYS's as a first option. Of course if you need to do this then you will have to accept the compromise in apparent scan speed.
My unit is packed full memory-wise and, as far as I can tell, it does pretty darn good in terms of scan speed! In any case, glad you are enjoying your new unit (despite the speed issue)!
-Mike
torontokris
Toronto Canada
Are you monitoring them side by side and noticing they are slower?
Or just going by the specs?
Some people have complained the Uniden doesnt go as fast as the specs indicate.
I have one but havent done any testing.. I shold try one time.
Would be interesting to have them side by side with the same programming (as close as they can get since the set ups are different).
torontokris
Toronto Canada
Sinister is correct... they recommend the DSP first.
So update it to 1.3 Then go nuts go straight to CPU 1.6
Dont forget you dont have to put in 1.4 1.5 then 1.6
The updates include all previous updates.
From the PDF file:
Stick0413
Hopewell, VA
Unidens 100 scan rate is with conventional channels. They even state that.
DesertRatt
Yuma, AZ
CPU First, then DSP
Actually, Sinister was correct, but torontokris quoted him wrong. According to the GRE instructions PDF:
3) If you are upgrading both the CPU and the DSP code, we recommend upgrading
the CPU code first.
The part about firmware upgrades being inclusive of previous upgrades was correct.
Just wanted to make sure there wasn't any misinformation, floating around.
