If the following is true, then this is not really what I would call a discriminator tap. While it might be useful for the scanner to provide a datastream output, this really limits the programs that will be compatible with the scanner.
An example is Unitrunker. It recovers the trunked datastream from the AF output of a radio with a discriminator tap. It will need to be rewritten if the new GRE scanners only provide an datastream output.
A pure dataslicer output (like the old Optocom could do) on the serial interface could be more flexible since you could then recover the datastream from a PC application listening to the dataslicer output on the serial port. But once again, this would require applications to be rewritten.
I am looking forward to seeing these new GRE scanners. They seem to have some very cool features...
ka3jjz said:
The Wiki is, once again, your friend .... the answer is yes (the PSR600 has such a tap, and likely others...) However, the output is in some sort of ASCII format - it remains to be seen how much rewriting the developers for Pro96Com, UniTrunker, ect will have to do to make it work. How much data is in this ASCII data stream remains to be seen.
73s Mike
Update:
I just checked the Wiki and it says this:
-Built in discriminator data output in simple ASCII output using the PC/IF port
What is unclear is if this PC/IF port is a serial port that just outputs that datastream, or if it also contins the "real" discriminator level audio output...
