GRE Super Amplifier
StinkyB
Indiana
Does any body have any comments on the GRE Super Amplifier. I listen to my Pro-96 at work, so I can't erect an outside antenna, will the amp work to help bring in signals while I am scanning inside a building.
Thanks, Danny
trooperdude
SFO Bay Area and Las Vegas NV
Thanks, Danny
Search the forum here.
There have been prior extensive discussions on it.
StinkyB
Indiana
Was there suposed to be a link? I searched RR and did not come up with anything.
hoser147
Grand Lake St. Marys Ohio
You may experience front end overload on the scanner. Some have others have had good luck with it. Just depends on what kind of RF enviroment your in..................Hoser
Gilligan
Hagerstown, MD
I have one and I hate it. I have read that it doesn't really work unless you're out in the suburbs. I live in a metro area. It actually decreases the signal strength here.
StinkyB
Indiana
I thought it would help while I am at work, I work inside a concrete block building in a room in the middle of the building, I can recieve transmissions, some are weak, some come in OK. Is a whole lot less than when I am outside of the building. I do work in the Louisville Ky. Metro area. I definitley would not use it outside the building.
6Paul21
Florida
GRE Super Amp
I have two and they don't work well on Digital but are good on UHF & VHF basic signals. If you are using Digital save your money.
Ed
Dubbin
Findlay Ohio
Ed
Mine works really well on our 800mhz digital system.
