- Joined
- Mar 10, 2012
- Messages
- 124
I have not any issues with CPD, on my xts 5000.
Thanks, I only broadcast District 1 and 2 and will update if it was the antenna when it is installed. I thought of trying a antenna amplifier but have not decided to yet until the new antenna arrives. But last couple years the Tram worked fine and I am fairly close to the towersI have not any issues with CPD, on my xts 5000.
This sounds like the same issue I had way back about 7 years ago had a mobile in the car. Kenwood tk-760 had an issue with my tram antenna out of no where. Replaced it with a different one and everything worked again. Before replacing I had maybe 1,000 of range when receive and transmitThanks, I only broadcast District 1 and 2 and will update if it was the antenna when it is installed. I thought of trying a antenna amplifier but have not decided to yet until the new antenna arrives. But last couple years the Tram worked fine and I am fairly close to the towers
I am crossing my fingers it is the Tram antenna. I did notice the top bolt kept spinning, not sure what it attaches to but that may be the problem. I should have another antenna within a week, little better then the last oneThis sounds like the same issue I had way back about 7 years ago had a mobile in the car. Kenwood tk-760 had an issue with my tram antenna out of no where. Replaced it with a different one and everything worked again. Before replacing I had maybe 1,000 of range when receive and transmit
I am coming in late here but I suspect that storms, be it lightning or high wind effect their radio network. I am located in a terrible multi path area and when the Cleveland system is operating normally I have a yagi pointed towards Hopkins airport. Every time there is a bad lighting storm or high winds the Hopkins location seem to be affected. When this happens I must re-aim the yagi to the W130 site until the Hopkins location returns to normal. I don't know how or why but I suspect that it requires some manual intervention from radio service to correct the problem. I have seen it take up to several days before things return to normal. I gather that there is a lot of built in redundancy so if one area is affected the other tower sites fill in until repairs are made. Because my main fixed antenna is roof mounted and a pain to aim, I use a second yagi that I can easily point where needed until they fix whatever they need to fix.
Ron,Ok. For now I am doing pretty good. The Tram one I got this time has the whip that goes up in the air from the center. I put the long one in and it came with 2 shorter ones like 18" with a black thing on it. The whip that is in it now is like 36" straight stainless rod. Not sure if the black thing does anything but may try to put that in and take the long one out and see if it does even better yet
Thx Ed, good catch.Bud....west 130 and I-71 not I-77.....
Nope. The District 1 antenna is located at the District 1 building. Which is at West 130th just north of I-71.I thought maybe these towers might be a repeater for D1 which is only like 400-500 feet from me and is around 3+1/2 miles from 1st District by the old Terex plantView attachment 77270
I've looked over several of your posts and based on what you've described (garble & audio cut out) it sounds to me like you have an intermittent Simulcast distortion problem. Tom Swisher (wa8pyr) did a reply to an39511, who is having the same issue you are.The one I use to broadcast with is the BCD996P2 and upstairs I listen and post calls in a group using a handheld BCD325P2. The rubber duck didn't seem to do that great.
If I broadcast 2 districts and say I am aiming a Yagi towards 1 of the districts, does that mean I am only going to get the 1 district? All the districts actually get dispatched from a downtown location I have been in their dispatch center. But I know in the zone cars they might tell D2 to change over to channel 1 that D1 has some questions they want to ask. Just need to know for sure if a Yagi pointed in the direction of District 1 will also pick up District 2 or would I be limited to just 1 district. If I am limited then pointing to downtown may have to be the way to goI've looked over several of your posts and based on what you've described (garble & audio cut out) it sounds to me like you have an intermittent Simulcast distortion problem. Tom Swisher (wa8pyr) did a reply to an39511, who is having the same issue you are.
As the weather changes, it affects the signal strength that you get from each of the towers. Since none of your scanners are capable of handling Simulcast distortion, in my opinion your best bet would be to buy an inexpensive Yagi.
The ground plane antenna's like the Tram are omni directional. So your scanners are receiving out of sync signals from multiple towers. Your scanners are decoding these multiple out of sync signals, which is where the garble and cut outs come from. You need to receive a single dominant signal. The only way to do that is with a Yagi.
A couple of suggestions.
1. If you decide to buy a Yagi, get it from a company (like Scanner Master) that allows for returns. Just to be safe, in case the Yagi doesn't resolve your issue.
2. If you get a Yagi, plan on spending some time to find the best direction for reception. Most folks start by pointing in the direction of the towers they know of. I have a Yagi that I use to monitor MARCS. What I found out while testing the Yagi was, that I ended up having to point it in a direction where there aren't any towers. Moral of the story is, don't become fixated on the tower locations. Just go with the direction that works the best.
