GRECOM EZ-Scan Quick keys
I know their is a thread with these the quick keys, but I forgot the one I used alot, it wasn't CNTRL+A, it would select multiple lines, you would keep scrolling and it would keep selecting items, it wasn't CNTRL+S or any of the other ones that select a single item, it was an oddball
That's how it was kind of, it's hard to explain how the other quick key I used did it
Normally it would be to set certain TG's or Radio ID's with the same LED config, or to change newly imported TG's or Radio ID's into a Scanlist and remove them from the default, I'd hit CNTRL+something, I'd hold that down and select the items
OK, I just found the shortcut, it's CNTRL+SHIFTand hold down SHIFT while you select the items
