Greeley fire is now using talkgroup 9001 for fire dispatch. The remainder of Weld county remains on talkgroup 1907.
Shawn
Gilcrest
Shawn
Gilcrest
Good catch. Unfortunately that will end the ability to hear Greeley Fire calls at work for me.
...Greeley Fire "Channel 2" is Weld FG-2 1908.
I would consider the using agencies 'some folks'Some folks may consider those absolutes...
never suggested any of the 11 fire grounds (there is no FG-1) be removed from anyones list...but I would keep all 12 FG's in the scanlist
I only have the opportunity to listen to Weld fire TG's for about 45-65 hours a week and the only times I've heard other agencies assigned to preassigned FG's is during auto/mutual aid situations. Although, I have heard the big 5 assigned one of the odd numbered FG's when they ask for one. Certainly any talk group can be assigned at anytime for any use, assuming the unit assigned the TG has that TG in their radio.There's a pattern of sorts true however when things hit the fan dispatch puts incidents on any open FG group.
Windsor also has the Larimer County mutual aid TG's in their radios (4054,4055,4056) something not all Weld agencies bordering Larimer have, but probably should.Windsor still has an option with 4073 and 4074 groups assigned to them.
Those guys still show up on their simplex VHF channel also - 154.13Fredrick Firestone uses 9011 (Old Tri-Area) as a "company" TG.
as are the WINTAGs, SIMPLEX1 (channel 16, all zones in every fire radio in the county), and Weld fire admin 1-3 (1956,1957,1958).North Colorado Mutual Aid Groups are also a factor.
