Green County: home patrol 2 not receiving p25 mode
Kbbell
Monroe wis
I am a manager at a local Radio Shack store trying to help out customers
green co Wi updated county sheriff to digital 2 weeks ago
home patrol sentinel updated Monday 12/20 using version 12/19/2021
updated system then wrote to home patrol 2
3 miles from tower
squelch turned down
law dispatch is turned on
i hear it talking threw the live audio
tried it the the 10 mile range full data base , and threw a favorite..... no talking or blank signal (only heard 1 tone)
town talk (non digital) comes threw fine / ems page fine
what am i doing wrong
keith
smithken
Michigan
According to the database Green County sheriff is still analog on VHF. Since the digital information is not in the database the Home Patrol won't know anything about it. I would also suggest asking one of the administrators move this thread to the Wisconsin board.
Whiskey3JMC
Just another pesky scannist
Simulcastylvania, TE
Hi & welcome to the RR forums:
Perhaps your county migrated to WISCOM here and nobody identified & submitted the updated TGIDs to the database? Just a guess as this seems to be the trend with many other states. Anyway, yes as the posters above me suggested, might want to ask for this thread to be moved to the Wisconsin Discussion Forum, maybe they'd have a better idea there. Perhaps you may want to scan WISCOM then enable ID Search on that HP-2 to see if any unidenfified talkgroups come through to see if anything sounds familiar (assuming encryption isn't a factor of course)
Whiskey3JMC
The RR page for Green County mentions the county P25 system uses simulcast but I don’t see the actual P25 system listed. A
Oh, hmm...OK. Yeah definitely weird. No county-specific TRS's listed in the DB :unsure:
No P25 listed at all aside from the aforementioned state system & it doesn't appear anything THERE is simulcast...
Whiskey3JMC
Looks like they are listed as P25 (not trunked).
Ah I see it now, it's a miswording. Simulcast conventional P25 frequencies, not a "system" in the classic definition. Makes sense now
OP: Try these:
154.72500 KSB392RM230 NACGRSO1Sheriff DispatchP25Law Dispatch
155.61000158.94000 KSB392RMGRSO2Sheriff DispatchP25Law Dispatch
OpSec
All your WACN are belong to us
Monitoring the database
3 miles from tower
squelch turned down
keith
Any scanner that isn't a Unication or an SDS100/200 is going to have poor performance on a simulcast system like Green County just activated.
JoeBearcat
Uniden Representative
It’s the simulcast twist that throws me for a loop, not sure how this system would be engineered.
Maybe he means simulcast on more than one frequency?
Or simulcast repeaters with voting receivers?
Kbbell
Monroe wis
Conventional, non-trunked, P25 radio systems are quite common across the country, including Wisconsin.
the info from the radio teck that installed the new digital radios in green county
this is the info that is not in the database
Green County, Wisconsin
Radio System Frequencies and Channel Information
BAYCOM
version 5, 08/17/21
Digital P25 Channels
Channel NameConfigurationBase TransmitNAC1Base ReceiveNAC1
Sheriff 1Simulcast154.7250230158.9625230
Sheriff 2Simulcast155.6100231158.9400231
GRN FIRE (Fire Dispatch)Simulcast154.1600232159.1575232
GRN EMS (EMS)Simulcast156.2175233158.7600233
CNTYWIDE(Countywide)Simulcast155.8050234158.8425234
Analog FM Channels
Channel NameConfigurationBase TransmitPL/DPLBase ReceivePL/DPL
GRN HWY (Highway)Simulcast156.1800PL: 88.5159.0750PL: 88.5
PAGING2Simulcast163.2500PL: 71.9159.4125PL: 77.0
Jail (Jail Dispatch)Repeater155.6400123153.7850
Notes:
1​
State NAC Code Allocation for Green County: 230-239
2​
Paging channel should NOT be programmed into subscribers other than control stations used for backup paging.
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
Let's keep the below message in mind please...
OpSec
Transmitting the same information on multiple frequencies concurrently is not, technically speaking, simulcast...that would be simul-select or multicast. The term "simulcast" in the LMR world means multiple sites transmitting the same information on the same frequency at the same time and it can be on a conventional or trunked system.
Simulcast (when done correctly) requires extensive RF modeling of site location, antenna heights, TX ERP, terrain covered, amount of required talk-in/talk-out etc. so that transmitter launch times are synchronized to keep destructive interference to a minimum and/or steered out of a certain area.
It is, after all, FM - F***ing Magic :)
Happy scanning.
ozzie
mn.
Do you see any issues with monitoring these freqs with a Motorola xtl 2500 on conventional, as Motorola decodes simulcast very well.
k9tsu
Monroe
The Green County system is working fine, it is, as advertised earlier in this thread, the fact that it's a LSM system. My commercial equipment receives it just fine.
