Greenbrook / North Plainfield Help Requested
mondaro
Harrison, New Jersey
Hello Everyone, Need some clarification on the Greenbrook / North Plainfield Area, What does North Plainfield Fire / EMS communicate
when dispatched to Greenbrook Do they get the tone out on Somerset County Fire / EMS and then use Fire Region 3 when responding to
Greenbrook for an EMS Call ? Who are the Paramedics that respond to Greenbrook RWJ / JFK - Hackensack or Atlantic if is RWJ what talk group do they use on the NJ-PSIC system for dispatch? Finally what County Ops Channel does Greenbrook Fire Station 33 use for Fireground communications? Thanks in advance for the assistance, any other tips/suggestions would be appreciated for that area I have family there.
Tony M.
rr60
Tony, is that all? Only kidding. Things have changed after the first of the year.
Greenbrook primary EMS is now Atlantic, not 50 Fire/EMS. A new single unit is now based at 33 Fire is Atlantic 20. As a practical matter in this area of the County resources are thin, very thin. Wait times for Hospital based BLS can often be 15-45 minutes or more (just sign the RMA, go on your own). That is what you get for a zero dollar contract. There is no County based BLS. Any Hospital based providers may be called. Don’t overlook a municipal paid squad, EMS 4, Bound Brook. They are taking many M/A calls. There is no standard answer here. Throughout the Region every day, fingers are being stuck in the many holes in the dam. Fire Region 3, is primary for Fire. Lastly, 33/50 both use Somerset County TAC3 simplex, rarely. I won’t get up on that soapbox. Maybe someone will chime in that knows more (although that seems less and less, re: trolls).
Atlantic BLS 4761
JFK EMS 4545, 4547
RWJ New Brunswick 4407,4409
8A* 8B* RWJ Somerset TRS TG 901, 903
mondaro
Atlantic BLS 4761
JFK EMS 4545, 4547
Thank You very much, all the years going up to the house it's always been a trick to try to figure out what to monitor thanks so much for shining some light on this I appreciate it. Tony
FT752
Central Jersey
This covers all of RWJ in the Central Region, both Somerset and New Brunswick campuses. Generally, 8A1 and 8A2 would most likely be going to North Plainfield/Green Brook if RWJ is requested. But, depending on the day and unit location, New Brunswick-based 1A1 and 1A5 can be requested. 1A1 has a new truck that is still having the radio power/programming figured out, and 1A5 can have a pool of truck selections, some of which have zero radios. Having Somerset County access only does so much when they are in the truck, except for select BLS units who have APX 7000s.
Don't forget Northwest Region 2 (4197) as Atlantic comes up on there frequently to communicate with Somerset County, which select JFK units will do as well.
Regarding North Plainfield 50, Fire Region 3 for Fire AND EMS; while primarily for fire, it's all in one place until a structure fire happens for them, Green Brook, and/or Dunellen; at which point the EMS division will move to EMS Region 1 for the duration. PS TAC 3 when in-county mutual aid comes in- Plainfield has multiple portables, so only when IC determines that they need to move to TAC is when you'll see. Green Brook may use it more frequently, but I have few encounters with structure fires in their own town.
mondaro
Thank You - This is why its great to be a member on RR and feed provider it's about sharing information.
mondaro
I found this post back in 2016 when I was up in Greenbrook Monitoring an early morning fire in a building in RT 22.
Any corrections to this in the present day are appreciated.
Monitoring the GB third alarm this morning this was in play.
Greenbrook Fire - Region 3
Greenbrook Fireground - Ops 3
Somerset MAC Coordinators - Somerset Co OEM Dispatch TG 203 and 3248
( This Channel had the best Updates on what was going on O/S overall )
( Referred to the scene has the Greenbrook North of RT 22 plan for
coordinator M/A)
North Plainfield - Watchung Fire Channel
South Plainfield also heard here coordinating there cover assignment
Warren Fire Channel - Convl.
Middlesex Borough Fire Channel
Greenbrook Police
Somerset Co Alert Channel ( Dispatched Somerset County Cover assignments )
EMS Coordination - EMS Region 2
