I'm not familiar with the Greensboro system, but 8883 might be correct, if the talkgroup is being crosspatched to another talkgroup on the system.
Within the Uniden I-D number format, there are 16 variations for a Motorola talkgroup I-D ... 8880, 8881, 8882, etc. These are often referred to as status bit variations.
When a talkgroup is being operated in a normal mode - no crosspatching, no multiselect, no encryption, etc - the talkgroup will decode as 8880.
When the talkgroup is being operated in one of the special modes, the I-D number will increase by a number related to which special mode is in use.
A talkgroup being operated as crosspatched to another talkgroup will decode as having a status bit variation of +3, or 8883.
The first trunktrackers could not adjust for the variation. If a talkgroup was sometimes used in both normal and a special mode, you had to program in both I-D numbers to hear the talkgroup in scan mode.
Of the newer trunktrackers, some will adjust for the I-D variations by default. Others, like the Uniden 250 or 246T, can be programmed to recognize or ignore the variation.
Here's the status bit variation chart posted with the trunking system information, from the information section on RadioReference at:
http://radioreference.com/modules.php?name=Content&pa=showpage&pid=1
TTID + # Usage
ID+0 Normal Talkgroup
ID+1 All Talkgroup
ID+2 Emergency
ID+3 talkgroup patch to another
ID+4 Emergency Patch
ID+5 Emergency multi-group
ID+6 Not assigned
ID+7 Multi-select (initiated by dispatcher)
ID+8 DES Encryption talkgroup
ID+9 DES All Talkgroup
ID+10 DES Emergency
ID+11 DES Talkgroup patch
ID+12 DES Emergency Patch
ID+13 DES Emergency multi-group
ID+14 Not assigned
ID+15 Multi-select DES TG
Jeff Multer
Fort Mill, S.C.
