I use these antennas for receiving only. I have a dual band, tri band larsen, 800mhz, and cb antenna that I swap out depending on what I plant to listen to. Do I have any sort of ground plane with this configuration? Is a proper ground plane necessary for receiving? How can I improve my reception? Is antenna tuning necessary for receiving and how can I do that without a transmitter?
I plan to install a CB radio and Dual band ham in the near future. I plan to install those antennas on the roof. What should my spacing be between antennas? Should I run them front to back or horizontally? At the distance apart that you suggest can I damage any equipment when transmitting on one of the radios?
What differences will I see from using a mag mount vs nmo drilled mount?
I have spent time searching these topics but haven't found an answer to my specific setup questions. Any help and opinions would be appreciated!
'94 Toyota Pickup
'94 Toyota Pickup
