Ground System Enclosure
Rob_K
Tolland County, CT
I have just about everything I need to ground my outside antenna....except the enclosure to keep the ground system in.
I wish I had seen this before I purchased parts individually but, where can I get this enclosure? I've searched, EBAY, google, etc. and found all kinds of outdoor, NEMA utility enclosure but no where that actually sells it (mostly found data sheets with part numbers)
http://www.dxengineering.com/pdf/UE-2P-Rev0.pdf
I also need the cable feed-throughs shown at the top.
Thanks!
Edit: Trying a different link
tonsoffun
Senior Moderator
Central Ontario
Hi Rob,
If you have an electrical supplier around you they should be able to help find what your looking for. I wrote this article for the wiki and got my box from a supplier. They should have the connectors (Feed through) your looking for as well.
Hope that helps
Rob_K
Tolland County, CT
Interesting. The link I provided was the installation manual for this. I guess I didn't read the description close enough but yes, this what I need...(I thought it was an entire grounding system but it does appear to be the enclosure and the accessories to go with what I have)
Thanks for the replies.
-Rob
