Ground?
carsonbm
Reminderville, Ohio
I have read it is best to ground a radio to an outside ground, isn't the radio grounded when it is plug int a outlet? :evil:
N
N_Jay
Guest
carsonbm said:
I have read it is best to ground a radio to an outside ground, isn't the radio grouded when it is plug int a outlet? :evil:
Safety Grounding (the one on the plug) and proper gounding from an antenna, noise, and lightening protection standpoint are VERY different.
N
N_Jay
Guest
Re: Ground
carsonbm said:
Can you explain what you mean?
The safety ground has one purpose; To trip the breaker should teh case (or other grounded part, Ant, ect) become energized by a source of commercial AC.
Proper grounding of communications equipment does many things.
Grounding the Antenna (on some designs) acts as a counterpoise and improved opperation.
Grounding of the Radio and other nearby equipment reduces static and some internally generated RF noise.
Grounding of the Antenna system goes a long way to improving the lightening pertection of the system both to nearby and direct strikes.
As for what costitutes proper grounding, you will have to do a search.
Try looking at some of the commercail antenna companies' information, Polyphaser Corp, and/or Motorola's R-56 document.
