- Joined
- May 21, 2024
- Messages
- 2
Hello all...
Thinks in advance for reviewing my setup here...
I have the 60' Chameleon ECOMM II End Fed Resonant antenna. It's feed point is on a wooden mast attached to the side of the patio roof. It's about 25' up in the air. It runs out to the corner of my yard and is tied off at a height of about 7' using the brick wall, a short piece of 1x2 stuck in there, and then some paracord.
The RG8U cable runs down from UNUN at the top of the mast and transitions into my office/shack through flat window wire and then runs to my equipment.
I want to do some lightning protection at the point it enters the house. I bought the Intellitron LA-1105 Lightning Arrestor to place inline outside my window. The problem is my home's ground is on the other side of the house so I can't bond the lightning ground to it.
My question is this - if it is only used as lightning protection and with the way the LA-1105 works, is there any chance of creating a ground loop with my house? I'm not using it to ground my equipment.
Appreciate your help...
Rob
KK7TIF
Rob
KK7TIF
