atxpatriot
- Joined
- Jan 19, 2021
- Messages
- 1
- Reaction score
- 1
Hi All,
I'm new to amateur radio and I'm trying to set up my shack and could use your help. I bought a Tram 1481 antenna and plan to mount it on the side of my covered roof back porch. The porch is 20 feet off the ground, since my house is on a hill that slopes down behind it. The supports and frame of the porch are steel (steel I-beams and steel posts). The posts sit on concrete footers. I was thinking of putting in a 4' ground rod and connecting the ground rod to the steel supports with copper wire and then attaching a wire from the antenna to the steel supports, essentially grounding it through the steel supports to the grounding rod. Is this a good approach or would running a copper line down and connecting directly to the grounding rod be better for RF?
I would appreciate any help you all could provide.
Thanks in advance,
Rob
KI5ODQ
Thanks in advance,
Rob
KI5ODQ
