radiopro52
I'm going to add this rotator to my scanner antenna. The only concern I have right now is grounding. The mast I have is grounded. However, the antenna will be placed on another pole on the rotor and from what I see, won't make contact with the grounded mast, leaving that pole ungrounded. The two sets of clamps on the rotor are seperated, so there's no way for the pole to make contact with the mast. So do I have to run some more ground wire from the second pole, or unground the mast and just ground the pole the antenna will be placed on? Or should I not worry about it and just leave it be? Thanks for any help.
