Grounding Block for LMR-400 Coaxial
MrBailBond
What type of connectors do I need to connect LMR-400 Coaxial to a grounding block. Pardon my ignorance, I am new to this but am good at following clear instructions and assembling things.
prcguy
Depends on your frequency range. If its only for HF you could get away with an SO-239 type lightning arrestor/ground block but if its higher than HF it will probably be N type.
MrBailBond
I have the D130NJ Diamond Super Discone Antenna. I need something for the full range of the antenna. Please state type of connector and ground block needed.
prcguy
I would use a good quality lightning protector as the grounding block and N type connectors in your case. I usually buy new old stock units like this off eBay to save some $$ but make sure they are new in box and not used and possibly hit by lightning already.
