- Joined
- May 28, 2014
- Messages
- 6
I just assembled a 33 foot Penniger tilt mast on a piece of 4x4 wood cemented in the ground. I mounted my Diamond V2000A 6m/2m/70cm Base Antenna at the top and ran a 100 foot coil of RG-8 with two PL-259's, one connected to the Diamond and the other rolled up at the bottom of the mast, (currently). I also drove a 8', 5/8" ground rod at the base of the mast 4x4 wood.
Question: Do I cut the the RG-8 at the bottom of the mast and and ground to the ground rod?
How is this accomplished? I know this is elementary to some of you, it is my first hookup as a Ham.
Or, to rephrase, what do I need at the bottom of the mast? The 4x4 treated post is buried approx. 20 feet from the entrance of my house. Then another 20 feet run to my shack.
Thanks for all your comments.
