safetyobc
I have my scantenna mounted at about 30' and use the supplied 50' coax. I grounded the antenna with a pretty small wire, I don't know the guage but it is small. The spool it is on says 16 purple stranded copper. I grounded it where the U bolt connects to the antenna (Wire between the antenna and u bolt nut. It is grounded to a copper rod that also grounds my dish network dish. I was wondering if proper grounding would effect reception - mainly I listen to VHF-High. Would a heavier guage grounding wire help improve reception? If not, do I need a heavier guage ground wire for other purposes (close by lightening strikes)? Thanks
