Hoping to find some grounding experts. Bought a antenna Antenna Supermarket Eavesdropper Antenna This has a Zap Trapper (Antenna Super Market Zap Trapper Twinlead ) that must be ground. I will also be grounding the receiver Rad. Shack DX 394. The Zap Trapper I will ground using 6 gauge ground wire to a 5 ft. rod. And the receiver using 10 ( or more? ) feet of strap Groundstrap Cable to the same rod.
Questions: 1) Is it OK for the ground wires/straps to touch? I'm trying to drill as few holes as possible and would like to run the two through the same hole to the rod outside.
2) The lug/loops on the strap Groundstrap Cable anyone think it's OK to add 5ft to the 10ft strap just in case I need more length? Using copper/whatever nuts/bolts?
Thanks!!
Thanks!!
