Hotsauce142
- Joined
- Nov 29, 2023
- Messages
- 5
I recently moved and I'm going to be setting up my HF antenna again.
At my previous location, my antenna was not grounded. I would always take it down, and unplug the radio and antenna during a storm.
I'm planning on continuing to unplug the radio just to be safe, but would like to keep the antenna up as safe as possible from now on.
From what I understand, grounding the antenna seems to be the way to go.
The type of antenna I have is a Comet CHA-250HD.
It is advertised as:
"No ground radials required and is not a 1/4 wave vertical, but an end-fed long wire type antenna with a matching transformer in a vertical position."
It will be approximately 35-40' in the air measuring from the top of the antenna.
My question is 2 part:
Does "no ground radials required" mean that the manufacture is stating a ground is not needed on this antenna, and its safe enough to run as is?
If I do need to put ground the antenna, is it as simple as putting an 8' copper rod in the ground and attaching a ground wire to somewhere on the antenna mast, down to the rod?
I appreciate the help... I'm still very new to the hobby.
