Couple of buddies came over and helped upgrade my online scanner (railroad) feed here in Western North Carolina that monitors local railroad traffic.
The Tram 1487 VHF antenna is mounted on a piece of metal conduit/bracket (see photo below) and the Coax runs down into the office and into a Kenwood TK-7180 radio (just located inside the far window)
1. I’m going to install a lightning protector between the radio and coax that allows a ground wire to be run outside to a ground rod. Does that satisfy “grounding the antenna”?
Searching online seems to be a rabbit hole of opinions. Just looking for some thoughts from the group.
